Yaris Ts 2004 Intake
imelman
The Apexi power intake is the way to go, it offers the best overall performance in terms of filtration and power.
Kevin
I am from Greece and I doupt if there is a dealer here. Is there an online store where I can purchase it? Is it easy to install? Are you sure you don't have a problem with the AFM (check engine lit)? Sound only or sound and power? Any dyno charts?
If you are looking for more than just sound I would recommend a Cold Air Intake...
Although the Apexi offers good filtartion I doubt there would be any real performance gain since the filter sits right beside the engine.
heat soak = loss of power :ph34r:
Do a search on http://www.echodrivers.com/forums/ for INTAKE....
You should be able to find some relevant info there...
:thumbsup:
