What oil do you lot use? I was thinking about going for fully synthetic and buying something like Mobil 1 but then I thought it would probably be better to go for something semi-synthetic like Magnetec because I tend to change the oil regularly. What do you lot think?
Toyota use Castrol GTX :rolleyes:
Its not all that great, but I'll be using it as my car has a FSH and I want to stick to the same stuff they used..
I've used Castrol GTX and Millners, and between the two I prefered the Millners, :)
Castrol Magnatec 10W40 Best for N/A's not sure about tubbies though... :thumbsup:
Shouldn't matter to much about if it's an N/A or turbo.
Oh and I find Magnatec to be more of a treakle substance than a oil. :P
But I suppose it will do, for normal road use :thumbsup:
I'm not conviced with manatec...
addatives.......
I place it alongside prolong ;)
Castrol Magnatec !!!!!!!!!!!!!!!!!!!!!!!!!!!
most over rated oil on the market! dont use it!
wouldnt even put it in a fiesta........earl, drain the rubbish out and put something else in. pop down to hyeline proforance, he will advise on the best oil for ur turbo car.
once again peeeps.......dont use Castrol Magnatec.
cheers baz
cheers baz
I'm off there tomorrow dude.
BTW... Howz ya bonce from the weekend, ya pish head :lol:
Mobil 1 15w50 at the moment, but next oil change is gonna be 10w40 or 5w40 cos of the cold weather coming...
