I Had An Idea
pedro7680
gen 5 celica.
im going to make myself some stylish dials,
but im needing a bit of info,
how hard is it to pop the dash out?, any forseeable problems?
what material is the dials?.,
etc etc etc.
im thinking of scanning the originals to pc and then working on the designs with photoshop?
anyone give a bit of feedback
thanks
dash is easily removed , the speedo cable if it has one can be a problem getting it off , the dials are usually tin , some are plastic .be carefull of the pointers though they are very easily broken :thumbsup:
drop the steering wheel , take off the shroud i think 4 screws, , you should then see 4 more screws which removes the clocks , to unclip the speedo if its like cars i have worked on , squeeze the built up areas and it should pull off.
thanks im off tommorrow, so will have a proper investigation,,
oh maleborn? i have a very "enthusiastic" idea for the dials,, if i pull this one off, things will be sorted!! ( IF )
