Put it in the for sale section dude :thumbsup:
No can do buddy, not a trader!
Im 99% sure the MR2 has a non-interference engine, I have seen on several motors when doing the timing belt turned the crank completely over without damaging the valves. People talk about the valves being bent because on high milage sometimes there is a lot of carbon build up on the valves and the pistons. In extreme cases this can cause the valves to contact the pistons when the timing belt breaks at speed.
Cheers
KiwiMR2
Had a look in the Celica manual and it does cover cam belt changes on 3SFE engines. If you feel up to changing it and want me to photocopy and send the pages to you email me on limeymk1@hotmail.com.
Have you checked to see if the belt is broken or slipped? It's not difficult, just remove the top cambelt cover, it's held on by about 6 10mm bolts. To check for slippage/mis-alignment of the belt, rotate the crank shaft pulley using a ratchet (19mm socket) to TDC (top dead centre), there should be a mark on the pulley that once aligned with the 0 of a graduated scale on the lower cam cover indicates that the pistons are at TDC. At TDC the cambelt pulley should be in a certain position, there is a small dimple on the pulley just outside of the fixing bolt this should be at the 12 o'clock position when the engine's at TDC.
I'm writing this from memory, I read it last night but couldn't get online to reply so I can't guarantee the accuracy on the campulley markings.
HTH
Chris
Cool Chris! thanks for that.
If you could get a photocopy that would be wicked!
I havent managed to have a look yet, but I will be doing it soon enough! :)
Ok, I'll sort that out tonight. :)
Sometimes its actually easier to just drop another engine in mate.. if the orst comes to the worst.. I'll bet you can get one with all the needed bits to fit it off findapart for about £400....
I may have a look...
you got another car then fella?
A little run about?
Nah not yet dude, Having a look at a VW golf driver, a 1994 escort, and a fezza later today...hopefully find a little runabout to just get to and from work in...
Milly just bought a vauxhaul ashtrey for £100.
its nothing tastey, but it does the job for less then not much money!
I might have a 306 1.9 TD...??
306 TDs are pretty good. Adjustable actuators! Loads of torque.
Why not just get the car fixed with the money your gonna spend buying a run-about? :huh:
Its kind of a blessing in disguise really, I needed a car thats better on fuel consumption as I drive for my business etc, and something that can carry my drums about...
Im stripping the car completely, selling the bits off it, and then my mate is taking it off my hands. When I can afford it, ill either be going the GT4 route, or an MR2 tubby, probably about february time, but its probably the best option for now! :)
Im still gona pester all of ya though :D
