"fogs" In My Lexuslights! Help!
eternity575
could be you have a bit of a water leak problem?
or it could just be the cold?
thats if its cold in Israel this time of year :lol:
Mmm... could be the rubber seal around the light wasn't water tight. I get condensation on the outside of mine. They shouldn't get water in at all, so I would check the seal around the light.
i used to have that problem with mine, apart from with mine i could of had a few goldfish swimming in the bottom as at least a 1/4 of the light was full of water. Over time i kept taking the light on and off, and jaxx reccomended i put some clear silicone seal round the edge of the light and that did cure the problem :thumbsup:
Tom!!
clear silicoln
works every time
just run a 'bead' around the inside edge of the clear plastic cover
also dry it out by putting it in a warm dry area like an airing cupboard for 24 hours
