Tyre Pressures?
noticed the other day that one of my rear tyres is wearing in the middle only, which normal means the tyre is over inflated.
but it was only at bout 26 psi.
any one know what it should be? :blink:
If running standard 15" wheels...
Front tyre: 195/55 x 15", 29psi
Rear tyre: 225/50 x 15", 33psi
HTH :thumbsup:
Hmmm, I was told on one of the forums it was 32psi up front and 35psi at the rear :(
Depends how you like the car to drive, in the summer I used to run 34 front 37 rear...
Wasn't the best for tyres but they wore through evenly and drove great.. .
NOt a good idea n the wet though
30psi front,
35psi rear.
my massive 14's are 28 front 32 back...
trye pressure should be same for car no matter if your running 14s or 17s!
