Hi anyone out there ever changed estima headlight bulbs. If so, is it difficult, also is it possible/practical to swap for the newer brighter style.
Thanks Jimo.
  • 1 year later...
After you remove the plug, remove the rubber cover and unclip the the spring, (push in towards the bulb) and remove the bulb. They are standard 3 prong 60/55w. I replaced my bulbs with 50% brighter from Halfords, By on get on free. Much better.
Good luck
Roger.
