I'm restoring my 92 paseo and I ran in a little problem (or big ) .It looks like my paseo is losing its coolant ,well I'm not sure where but I can tell It from the location of were its faling .It seem to be my water pump.Could anyone tell me tips to get this water pump out cause it is realy in a thight spot and well in canada labour is NOT cheap so I want to do it my self ! Thanks
If it is the water pump then the easiest way is underneath.
The following is based upon a Sera, which is going to be similar.
REMOVING A WATER PUMP
PARTS & TOOLS REQUIRED:
10mm, 12mm and 14mm sockets and spanners
a variety of socket extensions
a container for coolant (capacity - up to 5 litres)
The water pump is fitted to the back of the engine on the left hand side. It is one of the more awkward parts to get to. This procedure requires the use of axle stands or a garage lift - a jack is not safe. It may be possible to do the job entirely from above by removing the inlet manifold entirely.
Water pump
34mm ID x 1.0mm cross section 'o' ring
PROCEDURE:
ABOVE CAR
disconnect Battery
drain coolant into container - there is a plastic wing nut on the bottom of the back side of the radiator
undo various hoses and electrical connectors to make room.
undo alternator adjuster (12mm)
remove dipstick
undo and remove dipstick tube (screw at top - 12mm). Alternator adjuster arm comes off with it. Block hole in sump where dipstick tube enters sump to prevent water and dirt getting into the engine oil.
undo and remove top water pump bolt - 12mm
BELOW CAR
remove alternator belt
undo bottom alternator bolt and nut (14mm) and move alternator out of way
undo bottom water pump nuts - 2 nuts, both 12mm
locate pipe running across block from water pump - notice it is screwed to block with 10mm screw. Undo.
using screwdriver or pry bar, lever between notches and water pump - any coolant in these pipes will leak!
water pump can now be removed from block
water pump nose can now be separate and changed with new, if not complete.
REFITTING
Refitting is the exact reverse of removal.
The original water pump was originally sealed to the block with gasket sealant, however this may not provide an adequate seal and any gasket compound may get disturbed when trying to refit. Suggest fitting an 'o' ring in the sealant groove - a 34mm ID x 1.0mm cross section 'o' ring (max 1.25mm cross section) superglued in place in addition to gasket compound should make a good seal. Any gasket compound should be used sparingly.
Note: refitting the 10mm screw that supports the water tube that exits the water pump can be difficult to refit.
Make sure that alternator is tensioned properly.
Make sure that any air locks in the coolant system are removed and also the correct level of antifreeze and corrosion inhibitor is in place.
Thanks man for making it very mush simpler that i though .But one question how could i prevent or remove air locks ?? thanks
