Whats The Difference
wedryjoel
Being quite new to gen5 ownership I've noticed a lot of you use or quote "ST202" and others.. So I looked under my bonnet and mine is ST182R.. could someone tell me the stats for this model... As I thought I had a ST202... I believe that my car is a Gen5 20gt16 on a 94 plate..
Thanks for any help
mass confusion here , is your vin plate either blmgfg or blmvfg
or is it a uk car with 17 digits chassis number ?
1991, august ST182, ST183, ST183C, ST185H
1993, october ST202, ST203
1994, february ST205
1994, september ST202C
1995, august ST202, ST203, ST205
1996, january ST202C
1996, june ST202, ST203, ST205
1997, december ST202, ST202C, ST205
1999, january ST202, ST202C, ST205
1999, september ZZT230, ZZT231
2000, september ZZT230, ZZT231
2002, august ZZT230, ZZT231
does yours have pop up headlights or the frog type 4 ones ???
Mine has pop ups on a L plate Which i think is 94..
if its an import though, it will be 1993 as production of the gen6 started in october 1993 .
i think the stats below will be your car , though i cant seem to find a st182r
Displacement, cc 1998
Engine model 3S-GE
Max.power (Net), kw(PS)/rpm 165 ps (121.36 kw) / 6800 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.5 kg*m (191.23 N*m) / 4800 rpm
Power density 7.7
Engine type Serial 4 cylinder DOHC16 valve
Engine information
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded premium gasoline
if its a blmsk ,blpsk,blmgk, or a blpgk , which can be found on your log book as the chassis number then power will drop dramatically :crybaby:
looked at log book and chassis doesn't show any of those codes. I was told it is a uk model.. Is there any thing how i could tell if it was an import by looking at it .. Its not 4ws and possesses regular uk number plates chassis no JT164STJetc
agh that explains alot then . if you could send me the full chassis number i can tell you engine spec and date of manufacture for you. maleborn1967@aol.com
17 digit is uk car :thumbsup:
it was probably made june 1993 :thumbsup:
its a 1993 built in month 6 , engine is a 3sge :thumbsup:
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
