The Generation 5 Celica.
pedro7680
um........................ they are fast.
they have 3 doors, and 5 seats.
did I mention they are fast.
lol
Nice one Asha. :lol:
Blatantly lifted from the web:
GENERAL
Body type Coupe
Drive FF
Transmission 5 speed manual
Displacement, cc 1998
Frame E-ST182-BLMVF
Price of new car, thousands yen (Tokyo area) 2120 (~$17600)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4420 x 1690 x 1305
Interior dimensions (LxWxH), mm 1705 x 1410 x 1075
Wheel base, mm 2525
Treads (F/R), mm 1465 / 1440
Ground clearance, mm 160
Curb vehicle weight, kg 1270
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 3
Min.turning radius, m 5.2
Fuel tank capacity, l 60
ENGINE
Engine model 3S-GE
Max.power (Net), kw(PS)/rpm 165 ps (121.36 kw) / 6800 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.5 kg*m (191.23 N*m) / 4800 rpm
Power density 7.7
Engine type Serial 4 cylinder DOHC16 valve
Engine information
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10.1
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.2
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 205/55r15 87v
Tires size rear 205/55r15 87v
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Strut type coil spring (stabilizer attaching)
Suspension system, rear Strut type coil spring (stabilizer attaching)
Some of that info looks a bit dubious mind (seating capacity is not 5 persons, and the 15" wheels were an optional extra on UK cars).
BTW 165 ps = 158 BHP
IIRC top speed quoted as 138 mph (must have been downhill with a tail wind!)
0-60 = around 8.5 to 9 at a guess.
What else do you need to know?
