THE ENGINE MANAGEMENT SYSTEM LIGHT COMES ON FOR ABOUT 500 MILES AND THEN GOES OUT. MY GARAGE (NOT A TOYOTA GARAGE) HAVE DOWNLOADED THE ENGINE MANAGEMENT FAULT LIST AND REPORT THAT THE FOLLOWING CODE NOS. ARE THE PROBLEM;
PO420 AND PO430 CATALYST STSEM BELOW THRESHOLD ????
CAN ANYONE TELL ME WHAT THIS IS PLEASE - IN DIZZY BLONDE LANGUAGE PLEASE!
(ALSO PLEASE DON'T TELL ME TO GO TO A TOYOTA GARAGE AS DON'T HAVE THE CASH AT THE MO...)
HILARY
DTC
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Description
Indicates Bank 2 catalyst system efficiency is below the acceptable threshold.
Possible Causes
Use of leaded fuel
Damaged HO2S
Malfunctioning ECT
High fuel pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler /tailpipe assembly
Retarded spark timing
PO420( no cat)
PO234(waste gate)
PO335(crank Sencor)
PO340(cam sensor)
check that the car does have a catalytic convertor on the exhaust system , this could be leading to both faults if its missing , if it has one chances are its dead. :thumbsup:
take out your efi fuse for 15 seconds and replace it or take off the earth lead from the Battery for 15 seconds and replace to re set the error codes they may not come back on.and stick to unleaded fuel if its petrol engine. :thumbsup:
click here for the best blonde explanation i could fine honey .
http://www.obd-codes.com/trouble_codes/generic/p0420.php
http://auto.howstuffworks.com/question482.htm
THANK YOU SO MUCH MALE 1967! - NICE CLEAR INSTRUCTIONS - EVEN A DIZZY BLONDE CAN UNDERSTAND!!
I'LL GET MY CAT LOOKED AT!!
H
PO420( no cat)
PO234(waste gate)
PO335(crank Sencor)
PO340(cam sensor)
take out your efi fuse for 15 seconds and replace it or take off the earth lead from the battery for 15 seconds and replace to re set the error codes they may not come back on.and stick to unleaded fuel if its petrol engine. :thumbsup:
