Resistor Thing
seveer unaek
eBay item - Click here!
I've seen these things a fair few times and have always thought it was a con as it sounds dodgy to me! Another case of 'if it was really that good we'd all have one'
Anybody know what it actually is and does?
Yes, it is one of those "if it was really that good ..." things.
It is wat it says, a simple pennies worth resistor which is put in the wiring between AFM-sensor and ECU, altering the values the AFM sends the ECU, and tricking the ECU into changing injector duty cycle.
It is no way as claimed a "piggyback", what a joke that is, and it will harm your engine in the long run. And of course, always steer clear of jokers using the words "fast". And "furious" in the same sentence. :D
Cheers, Yves.
if you  still want one, I can get it for 2p
If you realy want to know it's a MRS25 4K7 wouldn't bother though it'll cost you more that 2p in the long run
I had a feeling it was a 2p resistor... iv used them in electronics before and it aint designed for improving anything really! (In this context) Just thought i'd clear it up. Job's a good 'un!
You get a lifetime guarantee...should your mod fail in any way just return it for a free replacement
People really will try and peddle any old PoS....
starting bid £4.99... :lol::lol:
