Oil Recommendation
kentishbh
Hi to everyone
What enfgine oil would you guys recommend for the Yaris 1.0 ltr.
Average temperature ranges from 10C to 40C round the year.
These are the synthetic which is available in my country:
Elf 5W40
Mobil 1 0W40
Valvoline 5W50
Esso 5W40
Which one would you guys recommend for my temps?
Kentish
Vitz 1.0 Yr 00
30000km
You can use any of these oils as for as viscosity vs. ambient temperature is concerned.
I would look at the oils ACEA rating and then use the one with the best rating (ACEA A3-xx, where xx stand for year of issue).
Also change the oil filter at the same time you're going to use another oil type. The stock Toyota ones are very good at their job.
Cheers, Yves.
Hi kentishbh
Not knowing your location/country.
Why go for a fully synthetic oil.?
You have a 1Ltr Yaris or a Farrari?
Go for a semi synthetic like Comma Eurolite 10/40.
Comma, also mix and supply oils for VW, Unipart etc, so
dont be fooled by big names you will be supprized about oils and "so called big name manufacturers"
If you really feel you need to go down the road of Fully Synthetic, ?? Comma Syner-G
a 5/40 you just have to check out the prices and compare with Comma to see.
But think on Semi Syn' costs much less, you can then change the oil twice.
RT
