2001 Corolla Stereo Problem
r62envy
Okay, the other day the factory stereo just turned off. I checked the fuse boxes under the hood, pulled every fuse in the 3 fuse boxes. I then found the fuse panel behind the little storage tray to the bottom left of the steering wheel. I don't have the owners manual. Does anyone have a wiring diagram which will show which fuse goes to the stereo?
Look under the bonnet at the fuse box on the left hand side the fuse for the radio is called the dome fuse check that first.
Okay and if the fuse is good, then I have a bad radio?
  • 2 months later...
Did you manage to resolve this - I've got exactly the same problem in my 2001 Corolla - Had to have ECU and locks replaced then didn't drive for 5months when back on road radio busted!!! Assumed at was this - maybe not if you are having same problem.
