95 Corolla With A 4a-ge Swap
95corolla4A-GE
just swapped in a 4A-GE n/t and around 5500 rpm starts smoking black how can i fix this fuel presure regulator any help would be greately appreicated
Hi 95corolla. You may have a problem with your MAF meter. It may be damaged. Does your check engine light work. The MAF meter decides the mixture as does the Oxygen sensor. But, usually if you are running rich it is the MAF meter. Good luck. :thumbsup:
