Tte Suspention Kit
Mr.Nibbler
Hey all, i recently purchased and fitted the TTE height adjustable suspention kit as recommended by PaulT. Just wondering if anyone else has this kit for thier corolla E12? The kit seems to be great but i still cant get the front end as low as the rear going by tucking the tops of the tyres under the arches, the rear is fine but the front is still 10-15mm above the tyre. Is this normal for this kit? Second question is that at the base of the front struts there is an adjustment bolt with a hex keyhole and locking nut, whats this for?
Cheers for any help.....Paul :)
The front usually sits higher on most cars, because the front will be stiffer because it has to take the weight of the engine.
Second question, no idea :D
Thought about fitting it to mine but I like the comfy ride too much :D
Sounds like you should post some photos. Would like to see how it looks. How much travel are you getting on the front springs?
Cheers
Paul.
Yes it's nornal , cause in/on :D a CTS you won't get more lowering than 45mm at the front but 90mm ! at the rear (totally screwed down)
