Sat Nav/6cd Changer
GAV9005
DEAR ALL I HAVE JUST BOUGHT THE TNS200/6CD CHANGER UNIT OFF eBay BUT HAS NO CONECTION LEADS TO CONECT TO MAIN HEAD UNIT HAS ANY BODY GOT A CLUE WHERE I CAN PICK THIS UP AND WHAT SORT OF PRICE SHOULD I BE PAYING. DOES THE CONNECTION KIT PLUG STRAIGHT TO HEAD UNIT AND WILL I NEED ANYTHING ELSE TO SET IT UP PLEASE :help: MY CAR MODEL IS THE AVENSIS 2.0 SR IT HAS A CD PLAYER IN THE CONSOLE ALLREADY WILL THIS CAUSE A PROBLEM WITH THE MULTICHANGER
All avensis cars should have a prewired loom in to left hand side of boot (N/S) under carpet. there you should find connectors for sat nav and cd changer. You will need a GPS aerial aswell which plugs in to the smallest socket at the rear of the tns 200. Having said that the SR may not have one but i'm pretty sure it does.
Give it a bash and let me know
cheers
P.s. I know which item you bought on eBay. nice one :thumbsup: and if the loom is there it should be a 30 sec job to install.
cheers
P.s. I know which item you bought on ebay. nice one :thumbsup: and if the loom is there it should be a 30 sec job to install.
That is interesting! So behind the panel on the N/S (where you can turn the catch and open up a little cubby hole') there should be pre-wiring for a changer!
Makes life easy to DIY fit a changer. Thing is, which changer will work with a 2004 Avensis head unit?
cheers
thanks for reply i have checked this area with no joy have got a price off toyota main dealer 125+vat for sat nav and 60 for the cd changer can one be bought any where cheeper
cheers
not in the cubby hole, under the boot carpet on the n/s there should be the loom sticking out of the wheel arch.
what has toyota quoted for exactly?
cheers
THE WIRING CONECTION KIT FOR SAT NAV TNS200 AND WIRING KIT FOR CD CHANGER I ASSUME
You going ahead with it coz if not I'll buy it off you!
Cheers
YES GOING TO FIT IT JUST THOUGHT THERE MIGHT BE SOMEWHERE THAT SELLS
THE WIRING LOOM A LITTLE CHEAPER.?????????????? :yes:
Cheers
Speak to an ICE specialist you could fit the gear under the passenger seat (Just) and have shortened wiring to the floor maybe even custom made. Another option is to go to a scrap yard and rip out a loom from an old car. All GS GLS & CDX will def have the loom to the boot.
Regards
Cheers
Regards
never thought of that will head down tommorow and have a look round before i buy from dealer cheers :thumbsup:
