T-sport Engine Oil?
T V O R
I’m a little confused, been reading the user manual and it says the engine oil for the petrol engine on a Yaris can be either of the following:
10W 30
5W 30
15W 40 or
20W 50
So which one should I use? Or doesn’t it matter :blink:
10-40 semi synth
you can go full synth it wont matter its a modern engine
yeah... I'm currently using Mobile 1 and it's 0w40 and I think it's a bit too thin... will most likelly try out 5w40 or maybe go with 10w40 next time...
10w40 is most common...
wouldn't personally use 15w40... especially at winter time - too thick...
OK, looking at the manual it seems it depends on the temperature on what type of oil should be used.
With the British weather as it is it is a toss up between
10w 30 (-18 to 38+ degrees centigrade)
15w 40 (-10 to 38+ degrees centigrade)
The other two types are:
20w 50 (-7 to 38+ degrees centigrade)
5w 30 (-29 to 10 degrees centigrade) Artic conditions!
:thumbsup:
I think I will go for 15w 40.
lee
10-40 or 15-40
Mobil1 or Millers are on my list
Castrol RS if you wanna go fully synth
Castrol GTX is pants aswell dont go there, heard too much bad stuff aout that! :wacko:
ive been told magnatec is the equivelent of putting urine in your engine
i chucked a bottle in the MR2 thinking it was good and everyone thereafter told me it was pants
so itll be drained soon!
im using magnatex + its great, our guys from mobil tell us its better than mobil 1.
Now I’m confused!
I use Millers 10w 40 fully synthetic in my T-Sport with a TRD Filter and the car runs great!
HTH
Kevin
HTH
Kevin
millers 10-40 it is then, prices? dealers? anyone?
thanks
Lee
:thumbsup:
if anything i will recommend Millers! get it!
magnatec is cack
oh and Kevin you wouldnt be a Millers stockist would you?? im finding it a pain to get hold of :(
