Gear Change Cable Mod
tezza72uk
I have read in the forums of a modification to improve the clunky gear change on the Yaris. Does anyone know if this mod. is a kit that can be bought, how long it takes to do, and if it really does improve the gear change? I am now on my second gearbox the first had a problem with a noisy bearing and clunky change, the new one also has a clunky change, a fault I have had with another model of Toyota with a cable change. Thanks in advance for any replies!
its a linkage a not a cable avaiable from toyta for the 1.0l i had it fitted to mine under warranty, was noticeably better but gearbox breaking dont think it will stop that
I think the gearbox is great! It's short, has a nice clunk as the gear goes in and it's easy as pie! You can flick it around with no effort, even one finger! Brilliant for speedy junction exits!
I think you may be thinking of a mod that can be bought in the states (from echodrivers forum) that replaces the rubber bush on the gear linkage with one of brass.
