Require Help With Amp Power Wire
M3K
Hi pll, sorry i havent been on here for ages, university is doing my nut in...
Anywayz, ive had a new sub and amp for xmas and i can't figure out where the power cable should be going, ive tried the rubber bulkhead by the Battery but the cable gets stuck and wont go any further.
Also ive taken the glove box out and still no joy. :ffs:
plz help me on this one, i really need some good bass, its driving me crazy
M3K
push a penknife through the large round rubber grommet behind the Battery. dont cut the wires!! the grommet is double skinned so make sure you go through both sides. only a small cut about 15mm (horisontal cut) then take your yaris ariel tape the power wire along side it (taped on the end) then push the ariel through the cut and down towards the foot well. feel for it behind the dash and pull it down de-tape it and remove the ariel (without pulling the wire back through :D )
