Fault Code Readers
tubaman
Anyone know if a Fault Code Reader is availavle for the later model Avensis ? (I know Gunsons make several for other models).
If it's the same as most other Toyota's a paper clip will do the job...
In the terminal for the reader short E1 and T1 turn the ignition to on and watch the engine management light, it will flash the code to you. You'll see an intermittent flash followed by a pause the more flashing....
eg. flash flash pause flash = code 21 = normally o2 or maf sensor....
much cheaper than a reader :D
