Rear Bumper Removal
mooser
Does anyone know how to remove the Yaris rear bumper. (plastic part)
My wife reversed into another car at low speed and it has popped a clip at the top passenger side. Now it's slightly skew and needs adjusting.
I found the bolts on the metal part at the bottom and that comes away. But the plastic part still seems very tight as if more clips are involved.
Tried just pushing it back but no luck!
:help:
Open the boot and there is some bolts there as you are looking down and also some under the arch I think? :thumbsup:
I have got that far - what else....? There must be a technique to it.
Under the bumper where the exhaust is there might be some, both the bottom parts will have to come off altogether I think, thats what happens with the front! :thumbsup:
I need to do ths job too, I'm having to fit reversing sensors for madam cos she can't park properly ;)
Anyone done this job and got any advice?
you do not need to remove the bumper to fit the sensor, simple drill the holes using the hole cutter supplied with the sensors
Parking Sensors???!!! On a Yaris???!!! This makes me laugh... iv seen them on a smart too!!! :lol:
it's quite simple... look out of the back of the car... that's the ar5e!! Don't hit anything with it!
