Lowering
armoredfist2002
I'm thinking of lowering my car in the new year, with just springs at the moment, how low can I lower my car with just springs, as I thought I read somewhere if you lower your car more than 30mm you have to use dampers/shocks as well as springs as the standard dampers will not allow more than 30mm.
Does anyone know more about this, as I don't want to buy just springs and then find out I have to buy dampers.
Also I have seen a koni ajustable suspension kit that lowers a car upto 35mm, does it just lower in the back, or will the kit lower 35mm in the front, as I only require a 35mm drop at the rear.
the car is a phase 2 2004 if this makes any difference to what I can do
thanx
If you get -30mm TTE springs you will not need new dampers! Infact if you get any springs you shouldn't need new dampers! :thumbsup:
I would recommend TTE or Eibach though! :yes:
ive have got tein s-tech springs on my yaris its 35mm at the front and 38 at the back and it looks the part....good around conering,not bumpy at all so i wud recomend tein..
I have a set of H&R springs they are amazing. Drops the car down to 35mm.Also increases the handling.Would recomend it to anyone who owns a Yaris.
Do any of these springs fit the phase 2 2004 models
yeah get the tte ones, they are a toyota part so you will still have your
warranty :yes:
Thinking about lowering my Yaris aswell - whats a good amount to lower it by, with absolutely no chance of scraping going over speed bumps etc?
Also, is the £100 the price of the springs from Toyota and could i get someone else to fit them?
Cheers. :thumbsup:
30mm's probably a big enough drop to make it look good and yeah just buy the springs off Toyota and get some else to fit them, its dead easy! :yes::thumbsup:
What Springs are on an SR? I Think they're 20mm TTE ones, but im not sure! I fancy another 10/15mm drop, so i guess i might pay toyota a visit for some lower dropping ones! Also, if i lower it... will the ride be much harder?
warranty :yes:
I was told I could do any mods to my car without voiding the warranty (except drilling holes for a spoiler as this voids your paint warranty)
any mods you do must be done with toyota parts and usually
by toyota too, to keep the toyota warranty up.
if a shocker was to leak with a none toyota spring the first thing
they would blame is that.
same goes if you put bigger wider wheels on if a bearing goes guess
what theyd blame!
same goes for most mods exhausts,air induction kits,lights...
i work at a dealers we will try anything not to pay out on warranty
work if its been modded!!
:lol::lol:
