Has Any Body Got Ecotec Valves
daz364
has anybody put ecotec valves on there yaris ts iv had one fitted by smart car in beeston the engine management lights keeps coming on every so often i take it to toyota they say it a weak mixture same problem its fine for a few months the it will light up and go off after so long and also does anybody now how to reset the ecu on the yaris without taking it to toyota
Unplug your Battery for 10 minutes, re-start and put all electrics inc lights, stereo, wipers etc and heaters on full inc a/c if applicable, then drive like a loony for 10 mins, then granny for 10 mins and then mixture for 10. That's how you re-set and re-teach your car! Although the re-teach you shouldn't need to do as the Yaris is very clever! Also, a reset ecu probably won't do anything either.
gimmicky crap
Yaris has an intelligent ECU, youll benefit for about 1 minute before the ECU figures it out and the adjusts itself to accomodate
save ya money and stay clear
my bro got 1 in his fiesta they are crap it does not save yur fuel it doesnt increase yur throtle reasponce all it does is make a silly dark vader noise grrrr...
300 miles to a tank... if you're filling it up to the brim (which at £40... sounds like you are) then that is poor mpg... you gotta slow down!! Thats less than 30mpg as the yaris tamk is 9.9 gal. Get some granny driving done... and do some coasting in 5th gear!
