Well fingers crossed someone will have an answer on this one.
I have just bought a new Toyota Previa T Spirit. This is the one with an integrated head unit for GPS with the GPS drive unit being mounted under the passenger seat.
I am looking to connect a hard disk mp3 player into this system. I realise that this head unit has no aux/rca inputs however in the past, it was possible to connect an aux adaptor to a multi cd changer port. I dont believe that this head unit is capable of a cd chager.
Have looked around the net but have not found any aux adaptors for this head unit.
To summerise - How do I get an RCA input into this head unit?
I did contact Totota direct but they advised that it is not possible. :ffs:
Any advice would be warmly received. :thumbsup:
Could you use an FM Modulator?
Hi - An FM modulator would certainly be the quickest easiest solution, however I have used one on previous vehicles and tend to find that they drift after a time.
If all else fails then this will be the solution.
