jim is wanting to remove the bump strips from the sides of my starlet s. has anyone done this and is it easy just to rip them off or do they leave holes in the sides of the car? if they do then we will probably get them sprayed so the car is more colour coded.
thanks
zara xx
nah theyr just stuck on iv taken mine off, use a heat gun or a hairdryer then peel off, carefully though i pulled a little paint off
you read that jim? i dont want to be respraying the doors!
Yes i read it, and im sure i can manage it ill just have to borrow some bits from work
Jim
There is holes behind the sr ones :wacko: i should know i tried when i had mine.
thats interestin cheers for that info i guess its remove and see :lol:
Jim
ud better not mess it up james.
but i trust you.
well you would think so letting you drive my car!!
What i would do is remove the door car then have a peeky inside see what you can see from in there :thumbsup:
Simon
all the starlets dont have holes behind the strips, as i have removed some off my Sr and off a customers sportif, shouldnt make no difference wether it is s/sr/xl etc etc they simply peel away (can be tricky at times as the glue is pretty solid)
thanks every one, there seem to be a few different opinions so its probably going to be best to look from the insides like sy suggested. :)
i rather my bump strips on i like the look of em but i never seen 1 without em so god knows if they look better without
well im not sure. theyre there for a purpose so removing them may get me some dents and i think they can sometimes break up a big block of colour which is good. but jim wants them off so...
