Econ Light On Dash
roy the boy
i noticed a while ago that the econ light is not working on the dash bottom right hand corner ,have had car serviced they said it was the bulb and would have to take out dashboard to get to it ,but i am sure its not the bulb ,anybody got or had the same problem.thankyou
roy B)
roy B)
Tis the bulb Roy almost 100% :yes:
Drop the steering column down, remove the 2 screws holding the cowling round the dials, remove the 3 screws holding in the speedo, pull speedo towards you and unclip the 2 scarts behind and the speedo is out. Then just twist out the bulb holder and change the 5mm 12v wedge bulb :thumbsup:
thanks ken i will look into it tomorrow
kind regards
roy :yes:
No probs, if you fancy coming along to the next Northern Mini Meet on the 23rd i'll change it for you as i've about 30 spare bulbs after the dash conversion :thumbsup:
kind regards
roy :yes:
thanks very much ken but i wont be able to make it there
kind regards
roy
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
