Turbo Timers
GT4 BOOSTER
i want to fit one , but my toad alarm unlocks the doors as the engine cuts , as part of the anti hijack program built into it. is it possible to buy a timer that ignores this toad alarm system or will i need to cut a few wires ??
I'm sure you need an alarm that is turbo timer compatable :( ..contact Toad :)
Knew guy that installed mine so got to to work off 1 off the spare fob keys, such as the window up button, but still wont alarm the full system till timer has stopped. Same can be done if you have standard key fob with door lock, once out off car with timer goin you can lock doors, but will still have same prob of not armin system till timers stopped. But lets face it, once youve pulled up n removed keys, then ubikd about takin stereo front off etc, timer will have prob stoppped anyway!
:thumbsup:
get the timer fitted by an auto elctrician who willmake sure all works together properly... toad can be modified to work with a timer..
