Need A New Engine I Think !
darrenc
hi , can anyone help me plz got a 91 n/a auto supra which the bottom end has gone apparently , the car has been at a local garage for last 5 months while mechanic tryin to find me a recon engine but no joy atm. Any help would be appreciated either by an enthusiast or professional its a shame the car is stood being left to rot so i want it sorting now i got a bit of time on my hands thanks :help:
you have two options...
drop in another n/a/ engine... or drop in a turbo one!!!
When my first mk3's bottom end went I put in a turbo engine...
I sourced all the needed parts for £650, and fitted it myself
more info here.
of course it would be easier fitting another N/A engine, just mak e sure its the same type! (they changed over the years)
try findapart to source an engine.
hi karma supra thnx for the reply, been away working hence the long time reply :)
ok , sounds as tho i may as well put a turbo engine in (well get a mechanic to do it for me) shame im not near you you could have done it for me if u had a sun afternoon free :P where is the best place to start looking for engine or do i just keep checking in this webby . Once again thanks for your help , my poor baby been left alone for so long
the other option is to get the current engine reconditioned....haven't got a clue how much this costs, but it saves searching for a suitable replacement
Rich
The problem with getting engioes re conditioned is cost, unless you will DIY, or have a mate to do it for free, it probably costs more to rebuild then replace.
last quote I heard was £120 for a crank regrind and reshell, and thats assuming its repairable... ontop of that its the labout of removing and stripping down the engine, new headgasket, headbolts etc...
try Findapart, thats where I got my full conversion kit from for £650.
www.findapart.co.uk
I can supply some of the bits if you need them (auto turbo ECU, boost sensor, and ignitor) but it'll probably be cheaper to get the lot all in one hit as scrappies like a nice barter :rolleyes:
