Mr2 Turbo Vs Starlet Turbo
just wondered has anyone raced a starlet turbo and is there much in it between a mr2 turbo and a starlet turbo
On the track there quite cappable :thumbsup:
well a mate of mine has just bought a rare 1999 light weight model and he will want a race soon i just wanna know if i should win or will it be to close to call i have a rev2 turbo
what kind of race, what mods have you done to both of your cars
And who's the better driver?
it will be off the lights like a qurter mile race and maybe a bit of a tear up down a motor way
i have induction kit and zorst but flexi pipe is blowing but my downpipe is on its way
he has £2000 on supesion setup a jams ecu and zortst and induction kit i don't know what else
Don't think i would stand a chance between Bibbs MR2 :(
4wd should give him an advantage with the launch.
But as i've found, that doesnt mean zit when you've got an un-experienced driver in it.
Besides MR2 take off exectionally well I find.
People who race me, say that I actually jump like a frog off the line :blink:
and that theres bags of torque pulling me through the gears
If you've got the spare cash.
my advice would be to put some tripple 8's from Toyo on.
if it's sunny thats all the edge you'll need
are starlet turbo 4wd drive then well i will have to wait and see what happens but i have never seen a starlet turbo floor it in the flesh so i have no idea how fast they are and i have only heard different views
In a straight line you should leave him late 2nd gear... well.. thats what happend when i took one on a while back.. was modded but not sure how much...
My car was unmodified at the time and also running only 7.5Psi of boost due to a problem i had. I was pushin 237bhp when i took it on...
Let us know how the car fairs.. i think you should have him though.. although i was well impressed with the little thing... defo pocket rocket! :thumbsup:
I think it was Toyota's answer to Nissan's GTI-R.
just a shame they never put a 3S-GTE engine in it.
Don't worry Shelly, you'd soon overtake me while I'm having to fuel up again .. :yes:
and you can get 3 peeps in your car .. I'd have to make shuttle runs :D
He asked about a Starlet Turbo.....are you guys all talking about a STARLET turbo!!??
The GT's weather it be a ep82 or ep91 they are FWD, AFAIA the only 4wd versions were the Reflet F. There is NO comparision between them and a MR2 turbo.......unless it is a well setup track car, and there are a few around. For drag racing they shouldn't stand a chance. FWD means even if it does have decent power it's gonna have some trouble getting it to the ground. The Glanza GT's I think weigh more than the earlier GT one's and afaia don't have anymore power....but look nicer ;)
I know of a few that have done the 3sgte transplant and there pretty sweet.
Cheers
KiwiMR2
Cheers
KiwiMR2
Glad you said that Kiwi, I was beginning to find it hard to believe. I had a blast with a Glanza turbo on the way home from work. Could have been racing a 1.3 Yaris! I nearly pulled his windscreen out!
What do you expect :lol:
The Toyota Starlet Glanza V is a 1.3 litre 2 door hatchback Turbo. It is part of the Starlet line but the Glanza shape was first released in 1996.
Engine 4E-FTE 1331cc DOHC 4cyl EFI-16-valve intercooled turbo engine
Power 100kW (133hp) @ 6400rpm
Torque 157nM @ 4800rpm
Weight 920kg approx
Speed 0-100kmh @ 8sec approx, 0-400m in 16sec approx
Boost Standard boost is 0.8 bar. Boost map sensor can read up to 1.2 bar approx
So what was all the cr*p earlier in this thread about? :blink:
...is it me???
...is it me???
No idea , i think people get the idea that just because
its got a turbo in it its a really quick car and its a mr2 turbo racer.
hell a renault 5 gt turbo, has a turbo in it
but its only 120bhp which is pretty close
to this starlet engine.
im just tellin you my encounter... Like i said.. it was a modified Starlet Turbo.... and it kept up with me to 2nd gear... end of...
Thats the only encounter i had... admittedly when i say it kept up with me i got a cars length ahead of it in 1st and in 2nd left him.....
Yeah but you can't exactly compare a 1.3 to a 2.0 MR2 :P
its a storming little car, but no comaprison to a 2 i would have thought?? :blink:
again... When your chattin abotu modified cars.. you can compare anythign you want against each other.. :bookworm:
At TOTB3 there was a Mk1 Golf beating skylines... now in standard form you cant compare the two.. but in modifed form.. thats a different story...
but that golf was cheating; it had two engines. :P
and no driver... it was driven by bender the robot omg :eek:
I believe thats my point... MODS.. :P :lol: :D
At the end of the day there great little cars, hell we have a Glanza S for the missus!! (LOOKS like the GT Glanza but no hole in the bonnet buldge, and obviously no turbo)
They have a good power to weight ration & I reakon the Glanza's look mint done up :)
A nice littl turbo upgrade (CT26 seems resonably common) and a nice front mount intercooler and there a quick little number......just not in the same league as the MR2 :)
Cheers
KiwiMR2
