How Do I Fix Over-sensitive Alarm?
NigelC
Help!! Just purchased a 2003 Avensis Estate. Problem is that alarm goes off all the time. I searched Internet and see some comments about reducing sensitivity of Avensis car alarm by "accessing a black box under a panel". Can anyone help me by throwing more light onto this and advise in more detail how to do this ? Dealer is useless and uninterested. Thanks in advance.- Nigel
dont keep anything metallic in car near centre console do u, if so take it out & see if it fixes
Why ???? Just curious how it affects the alarm system
Don' know about black boxes but try turning off the switch on the overhead console that disables the internal sensor, the one that you use if you leave dogs or kids in the car. It's next to the rear view mirror by the overhead light switches. That should at least narrow the cause down.
Sends tha alarm off due to a reflection in rays of the interior protection
Keys & coins are the main culprit near the gear lever
My Mate had similer problem on his Subaru Legacy, he took it back to the dealer and they reduced the sensitivity.
  • 4 weeks later...
if metalic things would set alarm off i think any brackets/bolts near sensor would set it off, unless toyota make body/bolts out of non metalic things
