Dear Previa owners!
My 1992 Previa 2.4 GL manual has idle issues!
When cold it stalls (unitl my foots been on the right pedal!) when hot it idles @ 1500 rpm (costly MPG).
I checked the idle adjustment screw to which I discovered it was wound in fully (minimum idle). All in all I would guess the cold start injector is running when not required and not running when it is required???
A Toyo. dealer gave me a clue being to two temperature sensors on the cyclinder head not sensing the correct temperature which leads to incorrect mixture thus giveing the idle problem.
As I have no engine check light illuminated I would pressume the sensors can't be completey...broken.
If anyone can give me a clue it would be much appreciated as im not relying on my non-specialised place of purchase to fix it under warranty. <_<
