hi just got my mr2 turbo, never had a toyota, or any turbo before, was wondering if my boost was ok, when the engine is ticking over, the guage reads - .03 and when on boost reads +.03 should it be more? any help i would be grateful with many thanks p
+.03 hmmm should be around +.05/+.06 like mine is , standard boost.
mine is halfway in between 0.5 bar and 1 bar what psi of boost is this
Ya thats about the same as mine , so podgey's seems abit low
oh no, does this mean its going to be a ****er? got and ideas why?, does your boost guage read 0 when ticking over, as mine reads -0.3
on ticking over it reads below 0 cant exactly say what take your car out when its all warmed up properly floor it and see if your standard gauge goes above the plus sign
Dont worry thats normal mine does too , to be honest i really wouldnt worry too much
probably best to wait for the experts to come online , but myself i dont see a problem it just seems a little lower than expected.
What year is your car? perhaps that makes a difference i dont know :!Removed!:
What revison of mr2 do you have
differnt revisons have differnt standard boost levels
your gauge will alwys read negative when at idle (vacume)
1.0 bar of boost is 14.8 psi i think <_<
we are talking about an after market boost gauge here arent we !!! not that piece of junk in the dash!!! :yes:
if 1.0 bar is 14.8psi does that mean 0.5 bar is 7 psi
Yep thats what i thought, i expect the REV 3 to have higher boost?
seams reasonable to me !!! :thumbsup:
thanks guys, its a 1992 j reg, dont know which rev? yes its an aftermarket guage. just a bit worried, thanks for the help.
when i got my mr2 it had no aftermarket boost gauge
and the one on the dash used to go half way (the 1st thicker line)
when i got a boost gauge it read 0.3-0.4 bar (about 6psi ish) (standard)
mr2 's have high and low boost - controlled by a valve (vsv valve)
my vsv was disconected, so i was stcuk in low boost.
once reconected - i got to high boost (about 8-9 psi on mine)
rev 1 turbo
1992 was the change over year for rev 1 to rev 2.
not sure if the boot level changed between these two, or if it ws only onto the rev 3, ill have to have a look.
check the vsv (i gues mine was diconected because some half wit was trying to mod the car ?!?!)
hmmmmm.. cheers where is this valve located?
Right, not sure how much you know (i am only new to this game as well really)
find your turbo (will be at the back of the engine as you look from behind - and accessable from the left hand/passengerside)
next to your turbo you will see your actuator (standard actuator normally a gold kinda colour) it will be a round disk about 2" accross, about 1" deep.
two pipe will be going to this actuator.
one from your turbo to to the 1st pipe, and then the second pipe leads to your vsv valve - its a b**ch to get to. just make usre that the pipe is connected from the actuator to the vsv(not cut and blocked with a screw like mine was
:thumbsup:
thanks for the info, il check that in the morning.
:thumbsup:
If the VSV pipe has been cut, it's probably because the previous owner had a boost controller of some sort on it.
:thumbsup:
yeah, mine was cut when i got the car, so thats what i assumed...boost controller, now i have a g-valve, and i have cut it again !! :thumbsup:
it should also read less than -0.3 vacuum under idle (when warmed up) normal idle vacuum pressure is around -0.6 to -0.7bar i think. Have you checked that there is no leak/kinks in the boost guage piping?
no havent checked that, i dont really know much about this stuff, im gona have to learn by the sounds of it.. thanks ..
Are you going to the Northern Mini Meet on Sunday?
If so, I could have a quick look over it for you. :)
cant im at work on sunday, where is it? would have gone. how often do people meet? thanks very kind of you.
It's in Leeds.
Dont think there every month but cant be sure on that one. :wacko:
i tried today to see if the pipe giong from the actuator to the vsv was cut, but its reaaly hard to see i had to feel down with my finger, as there was no room. i think its conected as i cant feel it flapping about. looks like im going to have to take it to a garage. dont suppose anyone knows a good garage to take it to in tyne + wear?
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
