Exhaust Blowing
winstonitis
Blew my exhaust the other day whilst having a bit of fun ;)
Does anybody know if the Jap GT-R exhaust is the same spec as the UK ST182? ie will I get any joy if I go to kwik fit (or the like) tomorrow for a new zorst? I think it is blowing at the joint between the centre section and the back box.
The reason I ask is that the 4ws may require a slightly different exhaust.
Cheers...
if it aint too bad , have someone weld it up , even cut it and weld some oversized exhaust pipe over the old piece , failing that i'm sure the boys at kwik fit will be able to sort you out.
any exhaust centre that makes it's exhausts to fit might be a better option, i got the front pipe on my GT4 replaced with a bigger bore pipe and they forgot to put in a resenator box that was on the standard pipe, such helpfull people :D plus it's stainless so lifetime garuntee ;)
