Bigger Engine In Yaris
scotty15
i paid about 155 quid. theres a few companys that produce an aftermarket pully for the eaton charger. a smaller one which increases the RPM of the charger, thus forcing more air out :D to start with im just gonna keep the standard charger, as i may need new pistons, valves etc if i go too over the top  :D
Start saving up. In the US people are destroying the 1NZ-FE well before 200bhp. You're looking at DOUBLING the engine's spec'd power. Think about how the internals have been engineered, with 108hp in mind... There's a reason Blitz and TTE/TRD don't make more than 150hp. The engine self destructs after that, and internals are NOT cheap.
Just a head's up... there's tons of boosted 1NZ-FE's in the US... ;)
well worth a read taking from www.elprototypes.com
Turbo charging the 1nz-fe has proven to be chore. It responds to boost quite nicely with a properly sized turbo. But its downfalls are the internals and its engine management.
Lets touch on the internals. First and foremost are the rods. Although quite strong for their size, they are designed for normal aspiration only. A half point higher in compression is about all they can handle daily without failure. Once boost is added to the equation, it becomes Russian roulette as to when they will let loose. You may last eight months with 50,000 miles or blow it the first pass down the street; there are no warning signs. We know this because of the testing of our turbo kit for the last year. The testing started on the Echo then was transferred to a Scion. The testing was controlled and only once was it taken past its set 7-psi mark while in our possession. Its one time high boost pass on the dyno was done to see how much the turbo would produce at maximum efficiency. Fueling and timing were changed to handle this. Every month the pan was dropped and there were no signs of abnormal rod bearing wear. The compression was straight across the board every time. The first motor lasted 6 months with about 35,000 miles. Its life was cut short while at the paint shop. Rumors placed it at the local street races near the paint shop, which they had for 3 weeks. All the baked on rubber in the fender well was the first clue. It let loose on its way back from them. A fresh motor was installed ASAP to continue the testing. The old motor was broke down to find the rod broke right above the crank pin. The dangling rod was beaten into the walls and punctured holes on both sides of the block. The second one let loose 12,467 miles later. It had seen one race with 3 passes at 9 psi. Fueling and timing were also changed to handle this. Other than that it was daily driven. The rods let go again, the same way, only this time it punctured the water jacket and destroyed the head. These engines have the crankshaft offset 12mm to the thrust side of the cylinder bore centerline. This reduces the side force generated at maximum compression, for reduced friction and improved fuel economy. Toyota calculates the offset crankshaft configuration reduces fuel consumption by between one and three percent. Unfortunately, this throws the angle of the rod way out on its upward travel causing the rod to just give up under boost and snap. If there is any detonation or pre-ignition this breakage will occur at an accelerated rate. The movement and breakage of the cylinder walls is the same as Honda’s open deck. Although we have yet to split one, we designed a block guard just in case. This product keeps cylinders from moving around and from splitting open the top of the bore. We are currently designing a forged replacement rod as well as a rod piston combo for high boost applications. The first of the sleeved blocks is being tested now.
Now for the ecu. It cannot handle boost in its stock form. Its timing is set for the stock parameters only. It will not handle larger injectors either. Piggyback or stand-alone management is needed to fuel the turbo properly, end of story.
From what we have seen, these issues probably were found by the likes of Blitz and Greddy long before we did. That’s why the boost on their kits was so low. The stock injectors will supply enough fuel for 3 to 4 psi if the MAF reaches full voltage and gets the injectors to 85 percent duty. Unfortunately you end up with a 15:1 AFR at peak rpm this way. Good for passing emissions but bad for the motor. The RS turbo Vitz has an ecu calibrated for the larger injectors that feed 150 ps at the flywheel which in turn is 127 ps at the wheels. The blitz s/c was turning 122 hp to the wheels without an ecu for the US market. With the ecu (JDM only), the s/c put down 129 ps to the wheels. It seems like the kits are limited to 150 at the flywheel but no one says how long it will last. Our turbo kit produced 144 hp and 150 tq to the wheels. That’s 170 hp at the flywheel. We have worked with several management systems and we will inform the public of the best one for our kit. We will release our kit soon but cannot warranty it except for workmanship. This kit will push your engine over the edge in the long run but if you build it our kit will be able to provide up to 250 hp at the flywheel. That’s 217 at the wheels. With all this said, it is up to you, the consumer, to decide whether this kit is right for you.
Copyright © 2004 E.L. Prototypes
Last modified: 01/11/05
Correct me if i'm wrong, but it seems like they had their boost too high. Hence why other companies such as Blitz had put the boost low. No, the engine wasn't designed for it and is a risk, but if you're willing to take it, go ahead. But get one you are pretty sure will be OK, such as Blitz or HKS that have already been used by Yaris/Vitz/Echo owners. But that's me opinion! ;)
yeap your right there it would self destruct thats what the guys at tte told me.
appart from that it wheel spins like crazy and torque steer is unbelivable
LSD is a must.
If the 2zz-ge fits then the 3sgte should fit too in my opinion :thumbsup:
255bhp stock (with the cats etc) Should make a good 300bhp Yaris without having to really do anything except turn the boost up :thumbsup:
(You'd obviously have to have a custom exhaust made up and in the process loose the cat :thumbsup: )
I believe Turb'd Engines create more pressure, hence *Pop*..
Huh? PSI is PSI is PSI. The pistons, rods and bearings don't "know" where it came from, if a turbo'd engine blows up at 12 PSI, then the s/c's engine will also blow up at 12PSI.
initally the charger is at about 165/170 bhp, runs bettween 12/15 psi. i think how you drive it can contribute to meltdown as well.
Are you trying to tell us that you're going to supercharge the car only to drive it at part throttle for the rest of its life? ;) :ph34r:
And that right there is the reason Blitz is making 150hp. Having plans of making 200hp means cranking up the boost (whether it comes from a s/c or turbo is irrelevant) ... Once you turn up the boost to make 200hp, you will destroy the 1NZ-FE.
Please read the great post quoted from EL Prototypes. They have blown up many a 1NZ-FE in the process of designing their turbo kit. The theory applies to superchargers as well.
could you fit a 3sgte in?
or maybe a supercharged engine like that in knowlsons corolla?
cheers guy's for the warm welcome. :thumbsup: i've got much to think about!! thought i loved the liccle yaris loads- but every1 here has put me to shame :( the meet in wales sounds good- but dont know if work allows it. will there be any meets up in yorkshire??????????? :D :D
Ay, sunday 23rd laddy. Me and a couple of others are meeting up at showcase cinema at 12pm before heading to ferrybridge... you're more than welcome to join us! I think im meeting Zee in Leeds too first, you can join in on that one too if you like!
Where abouts in leeds are you?
