Number Plate Not Flush
runboy
The front number plate attachment on a 2004 Avensis......
I notice that the number plate on my Avensis sits on a slightly proud lump of plastic. Difficult to explain, but in the centre on the number plate space on the front bumper is a protruding bit of plastic that means the bumper bends over it when fixed. It looks like its the mount for a smaller European or Japanese number plate, but why is it still on the UK versions? It means the number plate is not flat against the bumper.
Do all Avensis look like this at the front, or should I have a number plate mounting bracket on the bumper, then the number plate on that?
Make sense? If not I will try to get a photo on the site.
Mind has the same fitting. looks odd doesn't it! However by placing a small piece of black sticky backed foam sealant around the edges under the number plate ( thank you B&Q) , it seals the gaps and stops it vibrating.................
Cheers. I can't say mine makes a noise as it is well fixed, but it just looks a bit odd to have the number plate slighty bent over this middle bit of the bumper. Not the best design!
I'm not due to take the keys for mine until Thursday, but as its just arrived at the dealership I had an opportunity today to go and inspect it. I noticed the same projection in the middle of the bumper where you'd expect to fix the no. plate.
I don't know about any others here, but on my one, the fixing screws drive into this section so the plate remains level - whether that means either/both ends of the plate with 'flap' at any great speed remains to be seen. Halfords heavy duty double-sided fixing pads should quickly cure it if it does become a problem.
Jim
Thanks Jim-mine is fixed so the screws go either side of the bump in the bumper so no danger of the ends flapping!
Someone I know have seen front plates mounted on a plate mount i.e. mount is put on bumper and hides bump on the bumper, number plate then attaches to plate mount. Not sure I can be bother with time or cost.
Hope you like your new car Jim-I have the 2.0 auto T3-X too-lovely motor!
Thanks for the vote of confidence :thumbsup: - I originally wanted a 1.8 but the dealer couldn't source one to my spec's and budget. The only downside to the car is I have to hand over a substantial amount of dosh tomorrow :( Roll on Thursday when it's mine, all mine!
Jim
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
