Alright dudes, got myself some springs and shocks and i was just wondering how easy it is to fit them yourself, if anyone could give me some tips n crap would appreciate, got a Starlet Sportif EP91.
Peace
Soooooooooooo easy,5 bolts each at the front then 3 each at the back! Just watch those dodgy spring compressors!!!!
it is staright forward but do you have the right tools?
Erm, a few axle stands, a jack and a ratchet set, lol, that good enough??
hmmmmm a rachet set would do but those hub bolts are %$(ing tight. Is it 3/8 or 1/2?
beats the **** outta me, how do i tell???
i wish i was a grommet
Neither. They're metric, often 30mm. All fasteners on a Toyota are metric - ie a mm size.
To do the fronts you need a pair of spring compressors - otherwise you'll find out how powerful a compressed spring actually is.
The rears can be done without spring compressors.
Andrew
Andrew
Ok i'll have a bez, sounds pretty easy just need the right tools really and maybe a lift. cheers
What he ment was what size drive was the socket set 1/2" or 3/8"...
It's an easy job if you have the spring compressors.
Simon
