Headunit Speaker Wires
knightrider
for the front Speakers
i need to know which wires are positive and with are negative on the headunit ive got them paired up pink an purple, and green an blue (i think thats it but i know that bits rite just need to know which is positive which is negative?
cheers in advance
Lee
:thumbsup:
to find out if you have the correct pairing get a batterylike an (AA) and put one wire either end and it will make a noise if the two wire make a circuit which ever speaker it is as for getting it the correct way round do one plug them in to the head unit if the polarity is wrong there wont be no bass or not much if the polarity is right then there will be bass dont plug them in all at once if you got rear Speakers fade them to the front
here you go mate!
RIGHT HAND SPEAKER
POSITIVE - LIGHT GREEN
NEGATIVE - BLUE WIRE
LEFT HAND SPEAKER
POSITIVE - PINK
NEGATIVE - PURPLE
here you go mate!
RIGHT HAND SPEAKER
LEFT HAND SPEAKER
POSITIVE - PINK
NEGATIVE - PURPLE
gutted thats how mine already is ,,,,,,,,,,, hm maybe is hud try sum otha tweeters :o
