Fitting Cruise Control
andrewl41
I do a lot of miles in the course of a week and find my self wishing I had Cruise Control on my UK model Gen 6 GT. I was wondering if anyone had an idea (as I don't :) ) what would be involved in fitting this, indeed is it even possible if it wasn't fitted as standard?
Andrew
I read in someones camping magazine once, about a kit that you could fit to any car - so I would have thought it can be done,
might luck a bit ugly with a generic stalk attached though??
Thanks sotal,
I've just looked round and there seem to be a couple of universal options at reasnobal prices.
If possible though I'd like to fit the propper system for the car though I may consider a univeral system if it's the only sensible option.
Thanks again
A guy i used to work with had a jap import mr2 with cruise control , if u could find one in a scrapers i cant see it being that much trouble transfering it in to the celica , after all they use the same engine :D
Would love in my Cel
That's the sort of thing I had in mind. Do you know which bits would need changing? If it's a mare of a job I'll probably leave well alone but if it's simple enough then think it will be well worth the expence. I would imagine it's just a case of fitting some sort of throttle controler, hooking it up to the speedo and putting some buttons on the dash but I may be over simplfying it in my head.
Lot of time and money im afraid....i'd just make sure your next car has cruise :thumbsup:
