Gen 7 Headlamps
doormanpgd
Recently bought my wife a beautiful Chilli Red Celica, N/S headlamp has misted up, is this a known fault, if so any remedy please.
I also had another problem, which thanks to reading through the Forum's, I have solved, and that was the alarm keep going off, tracked it down to key's left in cup holder, thanks to that person.
Dave
check the bulb holders are in correctly.
common problem which toyota rectified around2002
new headlamp shouldnt happen again
So am Ilooking at new headlamps then? Sounds expensive!!
Dave
could you not dry it out with a hairdryer then reseal the lights with clear silicone
Where are you suggesting resealing, as I can't find a crack in unit?
