Air Con
Old Fart
Hi, Should the air con. make like a buzzing sound when at tickover?
It also does it in first gear when the engine is pulling hard.
Thanks.
Mine developed a buzz that I myseteriously dissapeared after one of my many battles running cables into the dash - probably something caught or loose ... if its under warranty get Mr T to sort it.
Nor does mine.... perhaps get it seen to?
I will take it back to the garage .
Thanks.
It's perfectly normal for your air-con to make a noise when you switch it on. You should hear the unit switch on and the power will be drawn to it, hence your revs should drop ever so slightly too. If it's buzzing though, it could be the radiator that's come on at same time.
If it's constantly buzzing or squeeking or rattling... then it's worth getting it checked!
