Clear Out
starletsy
Nomad oil pressure gauge as new they are £52 from nomad £30 including post to the UK:
St May EGT gauge it’s peak hold 60mm brought from eBay but never used everything needed to hook it up. Pics available on request. £70 including post within the UK. This pic shows a similar meter from the series:
HKS PFC f-con for EP91 Toyota starlet turbo comes with harness, head unit and boost sensor all in great condition £175. (This is not the one that’s just been on eBay came direct from Japan)
Calibre CA 80.4 Four channel amplifier, connectable as a 2-, 3of 4-channel amplifier. Max. 4x 80W (2x 160W mono), RMS 4x 40W (2x 80W mono) at 14.4V. 2-Ohm stable stereo.
Planet Audio 12” sub, dual 4 ohm vice coils this is a serious sub made in the USA that will need between 250 and 500W RMS fed to it. It comes with a custom built sealed Birch Ply box that was built to the correct specifications for the sub.
Jensen Nitro amplifier, 2 x 125WRMS or 1 x 250WRMS 2-Ohm stable
Brand new ANL fuse holder with a 300 amp fuse this is high-end kit for systems needing plenty of power.
2 x Fuse holders been used but in good condition these will take anything from 20-80 amp fuses
1 x distribution splitter block splits down the main power feed into two separate feeds also individual fuses again takes anything from 20-80amp fuses.
3 x RCA wires, power wires, earth wires, speaker wires etc all my spare audio stuff basically.
Pictures can be provided if wanted would like to sell all the audio as one kit for £250 ono. But might split if I get enough sensible offers for all the kit.
Located in south Lincolnshire.
Please Email me with offers questions etc.
Simon
