Hi.
I need to remove the old ad replace with a new heater matrix in my J plate Previa. Having had a look at the job, it looks as though it could be a dog of a job but, there's always the chance that someone may have some really useful tips to help me out. Otherwsie, I'm considering leaving it ion place and putting different one in the air intake box, with modified feed and returns.
Any advice very gladly accepted - it's cold in there!
Paul :D
NB: Have also posted this on 'Inside out' as not sure which forum is best suited to this query.
how would you go about dispensing the heat to the various air outputs having it in the air intake box bearing in mind you also need a fan to circulate the heat, i think your plan is daft.
You may have mis understood me there. I'll put the new matrix i8mmeditely in front of the old one - airflow won't be that great but it should put enough through to the interior of the car.
Your thoughts pls?
Ta
Paul
