Hi is it possible to get a stubby roof aerial for my 3 door xt3 Rav 4 as it catches the up and over garage door Thanks
Its got sat nav if that makes any difference
You can get a shorter aerial (try ebay) but you will find the reception is not as good, especially with weak signal areas.. The shorter the aerial the worse the rx will be. It won't affect the sat nav though as the aerial for that is in the dash.
And if you don't want to purchase a new aerial you can just cut the existing one but as moonranger says the recption might not be as good with a shorter aerial.
Thanks guys I found one on e-bay I would rather loose a bit of reception than damage the car roof I was just a bit worried because I didnt know where the sat nav got its signal from
