i had a split in a pipe on the cooling system, fixed it, now do i need to bleed the cooling system? or will it be ok?? :blink:
dont need to bleed the full system! just top it up and check it for air locks
thats what i thought bleeding did?
Start with a cold engine..
Fill up radiator...
Start engine...
Let engine run, and top up with coolant as needed..
Once all the bubbles have stopped, and the fan has kicked in twice - you'll be fine.
