Wheels On Ebay
andrewl41
I've been looking at a set of wheels and tyres on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=7951675141
They're to go on my st202. Does anyone know if these are likely to fit? I guess I need to check the offest and centre bore size but I don't know what these are for my car.
Any help would be appreciated.
u need to find out th eoffset etc before any of us can help email th eseller and ask what they were off
Is this the information I need?
PCD 100. ET35 TBX L400
He's just added it.
So to confirm here, PCD 100 is the distance in mm between the studs. ET35 is the offset. I think this is about right for the celica. Is this all I need to be sure of to know they will fit?
PCD 100, ET35 offset is correct. It is also useful to know the diameter of the centre hole. If it's too small the wheels won't fit, too big and they will fit, but will be difficult to locate on the hub.
Maybe L400 means that the centre hole is 40mm dia? Measure the hole in your spare wheel to see what it should be for your car.
If the centre bore is too large you can get spigot rings from most wheel manufacturers/retailers. :thumbsup:
Thanks guys,
I'll get out the tape measure tonight and get the seller to do the same.
With any luck they will be the same / larger and I'll soon be the proud owner of 4 new wheels.
Andrew
