Super Apexi Induction - Clean?
Sorry for daft question - however, what's the best way to clean an Apexi Super Induction cone filter??? Had it on my Turbo for a while now - real dirty.
When I used to have K+N filters, you would wash them under tap and re-oil etc.
This the same with the Apexi??
Cheers
I'd suggest a hoover .. don't think they are supposed to be cleaned.
Apexi do cleaning kits. Not sure how much tho. The kit for my Blitz was just under £40.
After doing a bodykit conversion thing, water has been draining onto the filter for past few weeks, looks terrible :-(
Bought a new foam type filter as a quick replacement...
Think washing it under the tab will do?? Worked for my K+N but then I would have to re-oil it etc...
Remember reading that this Super Apexi does not need re-oil etc...
Cheers
I've read somewhere that you can simply wash it under the tap.
I washed mine udner a tap, takesa ges to get all the dirt out. make sure its dry before fitting it back on!
I've got the Apexi too. Washed mine the other day in warm water and a bit of fairy. Let it dry out over night near the boiler, then treated it with some K&N dirt retention oil. Didn't realise it was red sponge until I washed it!!
Joe
