The Standard Head Unit
mrrandom
The standard hu doesn't hae any preouts, but if i'm not mistaken you can connect an amp up to it, just not quite sure how. I think breezer used to have his amp connected up to standard hu. But the sound quality just won't be as good at higher volume levels as would be with an aftermarket hu
its more than possible if you dont want to mess around with an aftermarket unit
and as dougs says you need an amp with high level input capability which most of them have this day
or.... an RCA converter, which takes speaker input and boosts it to RCA levels and then you do the normal connection with RCA leads
ging-gang-goo
I do indeed Ryan.... I have an Alpine V12 and 2 infinity 6x9s hooked up to standard HU... no sub tho...
PM me.. or grab me on msn for more info
