Dials. Change To Mph
MR2 liamb7
owned my rev 1 turbo for 4 weeks now and i really want to change the speedo clock to mph. i was gonna get some white mph dials but then realised that wont work on there own. i want to change the needle to mph, fit white dials, then get someone to change the milage to miles (if poss). has anybody done this conversion? :)
you have to buy a delimeter chip that will change your needle so it's reading from a 180mph face, then get a 180mph face. you can get these off eBay.
as for changing the mileage, i'm pretty sure these can't be done because it's classed as clocking the car.
you have to buy a delimeter chip that will change your needle so it's reading from a 180mph face, then get a 180mph face. you can get these off ebay.
you can change the mileage as its an import, just make sure you set it to right mileage.
or you can get a black permanent marker and remove the K on the dials, then get a white one and put a M there. :hokus-pokus:
Not like I did that though :ph34r: :)
I brought some UK dials(160mph)and swaped them for my kph ones and that was that,speed is now in mph and its distance is in miles and thats it.
Can't use a chip and it's a rev1 .. need a manual converter that sits on the G'box ..
