does n e 1 know where i get my speedo converted from kms to mph? and how much? im in the midlands by the way. cheers
Talk to andrew (toyotasera.co.uk) on this forum i think he can help you.
kits can be bought here for under £50 www.eliteinternational.co.uk
You can fit a small gearbox in the speedo cable which converts the gearing so that the dashboard reads in mph.
However, what was once 60kmh (37.5mph) now becomes 60mph and the speedo will read up to 180mph.
The useful part of the speedo is quite limited, and it can be hard to quickly glance at the speedo to check your speed because the difference between different speeds is only a few degrees.
ok thanx, where can i buy these gearbox's from? i think ive seen them in banzi
